2017 S3 - A\C not working
WALSALL
I have a 2017 S3 Saloon. However the air conditioning is not working. When I press the button the small light turns on but as soon as I take my finger off the button the light turns off again.
Any ideas?
Thanks
gwaijai
London
2019 Audi S3 Sportback
Hi, got the same issue myself, id you ever get it solved? I am going to check fuses tomorrow.
Cheers :)
GeorgeB
Stockholm
Sweden
Audi S3 Cabriolet 2015
What error codes do you get with a VAG-compliant reader?
gwaijai
London
I will have a check on Monday, I have a Youcanic, it has been able to read codes on the S3 in the past so should give me a good idea.
Will post what I find :)
GeorgeB
Stockholm
Sweden
Only VAG-compliant readers will be able to read codes from the AC as it is manufacturer-specific codes.
gwaijai
London
Hi,
I chanced it; read codes on the youcanic and got:
B10ABF0 - active/static - Refrigerant pressure lower limit not reached
Guess I am off to the FGAS man.
On a side note, is RossTech the best option for reading and coding on VAG?
GeorgeB
Stockholm
Sweden
Hi,
That's great! Remember to use the youcanic when you have a problem with your car before asking the community to tell you to use it!
Hi,
VCDS from Ross-Tech is still basically the gold standard for enthusiasts.
gwaijai
London
Thanks both for youir replies, happy to report ice cold a/c now.
I am still fairly new to the S3, I will look into the Ross-Tech as my next 'upgrade'.
Thank :)
