RS3 Pulling to one direction
Dus10R
Reno
NV
2018 RS3 & 2017 R8 Plus
I’ve had this problem for a long time but when it first started happening there were practically zero RS3 owners out there to compare notes. So I figured Id wait and revisit a forum later, now that more RS3’s are in the wild figure it might be time to check again.
Issue: Get in and drive away, about 1/4 mile down the road the car will all of a sudden pull in one direction, pretty aggressively. Feels like it’s applying a brake but only to one side and maybe only one wheel. You can feel the drag, and slightly hear it. After fighting through it for a few seconds it will stop and drive completely normal till the next you get it and go.
I don’t notice it as much on my winter wheels and snow tires. But the second I swap out wheels and put sticky summer tires on it starts to do it noticeably.
Does anybody know if they calibrate themselves when first starting out or something? ESC, ABS, ?
It seems to be gradually getting worse. Told the dealership about it a few times and they couldn’t feel it or just weren’t sensitive enough to it. May take it back now and see again.
RS03JE
Sydney
Australia
Audi RS3
Did you end up finding out the cause? I am finding this issue with my 2018 RS3.
