Exhaust Valve Issue? Causing Squeak
Melbourne
Australia
2020 S3
Hey all, wanted to ask about exhaust squeakiness. Noticed it today coming out of the left side when I’m not in “dynamic”. Just in “comfort” I wonder if it’s the valve? As it doesn’t come out the left side.
I did install a dashcam over the last couple of days and I’m wondering if I may have done the wrong fuse that might trigger it, or it could just be a coincidence that I’m hearing it now.
Sucks to be nitpicking on it but I wanted to confirm it as to what it is. Anyone know? Thank you!!
RS3JM
Reading
2017 Audi RS3 400PS
It gets worse if you leave it, and turns into a rattle and will drive you nuts. Ask if Audi will help you out otherwise you might need a tallented mechanic to get creative if you don't want to change the rear box. It is a sealed unit, thanks Audi!
ebidoul
Royal Oak
MI
2022 Audi S3
Took my 2022 into Audi service to look at this and was told even though they hear the issue its not causing any mechanical issues and they are not able to fix it.
I'd recommend emailing Audi Corporate to get this on file. If enough people do that maybe just maybe theyll fix it.
