are the rear sway bars on the A3 the same as the S3?
are they interchangeable?
DRTJRZY
NJ
they should be interchangeable since when ordering they are both listed for the same code. I recently upgraded my front and rear sway bars to EuroCode
OEM S3 bars are 24mm Front, and 21mm Rear
EuroCode 28.6mm Front, 25.4mm Rear
DRTJRZY;2529...I recently upgraded my front and rear sway bars to EuroCode OEM S3 bars are 24mm Front said:
Why the bigger front bar? I would think these cars would be more neutral with just the bigger rear. Do you like the setup with bigger front as well? I might do just the rear and see how it feels as I would like to dial out some of the plow. Interested in your experience. Are you tracking the car?
DRTJRZY
NJ
I do not track the car but I do enjoy driving her hard on back roads when I can. The sway bars are adjustable front and rear so you can dial them in depending on what suspension you go with. I had Bilstein coilovers with them both in the middle setting and the car was on rails with 2.0 camber front and rear and no toe in rear. Now with bags the car still handles very well surprisingly. So basically depends on what you go with is what you can do.
