S3 whirl noise
Not sure if this has been posted before so sorry if have.
I have a 2009 s3 and been having noise come from rear. Had the diff oil changed no gremlins in oil had the Hadex oil changed to again all good. Just wondering if it could be the swagg joint as I had this inspected and is a tear in rubber. This noise is really noticeable at 40mph and around 75mph. Don’t think it’s the wheel bearings as the noise doesn’t get louder around curves etc.
It could be, whenever there is a tear in the rubber all the grease inside is going to leak.
G
Sorry but it’s a thick rubber seal that goes inbetween the prop shaft and the rear diff. It’s there to takeaway away vibration. So being a tear I was wondering if this could be the source?
RS3Fan
I don't think that will cause the vibration if it's not a moving part. However it wouldn't hurt to replace any torn seals.
G
Gixxer1186
That’s it or referred to a ‘Swagg joint’ if deficient can cause noise apparently just wondering if anyone else had same problem.
