Recommended Air Intake?
KoRe401
Rhode Island
RI
2016 Audi S3 Premium Plus
Hey Folks, what do you recommend as far as an Intake? APR looks good but I've read it does not fit super great. Any other options or recommendations?
I went with the lower end 034 Motorsports model P34, fit well, easy install but I want to install an APR catch can system and I learned that one requires the APR intake. Keep that in minid as you shop and let us know how you like it once installed! Mine produces a bit more intake noise up front. Looks good, simple plastic. The stock one is garbage.
Broxbourne
2017 Audi S3 Sportback
I read on other forums that the next best thing to a racing line or APR intake was to remove the snow grate from the stock air intake, upgrade to a silicone pipe with a turbo inlet elbow and swap out the paper air filter. After much consideration I went down this route - given the relatively cheap cost - I'm pretty pleased with the results - when the car is pushed the intake noise is pretty good (nothing when driving normally though)
you should post a pic of the setup.
KoRe401
KoRe401
Rhode Island
RI
Sounds great! I recently removed the snow grate as well. Can you post pics of the silicone pipe and turbo inlet? Also, where did you get it?
if anyone needs the apr intake let me know. i get you one.
S3&A4Owner
Scotland
2016 S3
I removed the snow grate and installed an AFE cold air intake. Sounds great and feels quicker(AFE advertises 18hp and 20 ft/lb gain)
